That scrollwork looks to be a challenge. Can't wait to see the results!
http://forums.bit-tech.net/showthread.php?t=163797 I went through a few sheets learning how to cut the glass correctly. I found my glass at...
Have you thought about using stained glass for the panels? I used it on mine. Amazing work - hard to believe that is covered with veneer and...
More updates. I am almost done. I thought that I better get a computer put in this case, otherwise it would be just a piece of furniture!...
More updates. Stained the legs: [IMG] --- Here is the underside of the top panel: [IMG] --- Also finished sleeving the cables...
Excellent work - like the powdercoating and laser cutting. My only suggestion is to paint the USB plate black.
Another update. I decided to put the switches on the front panel instead of putting them on the metal frame. Part of the front panel had to be...
Everything looks awesome! One question, though - were the panels scuffed up before the airbrush was used? They look really shiny when the...
Update: Glass has been cut. The glass can be removed and replaced with different glass if desired. [IMG] [IMG] --- Pic of new...
Update - started staining the panels: [IMG] Also, I was thinking that I would stain the top frame and the legs a natural stain: [IMG].
No, but the top will have no openings, so when it is stained and sealed it should be okay if any drinks are put on top and they spill. Better use...
Hello. This is my second wood case. I started this one back in 2005 but put it on hold due to remodeling my kitchen. The main wood frame has...
Since this is inspired by Arts and Crafts, as well as Frank Lloyd Wright, I plan on having windows on the side panels, but you will not be able to...
Thanks. The cases are nowhere near as technical as some of the ones here - my eyes glaze over whenever I look at wiring diagrams. The gauges...
Started working on the wood panels. The front, sides and back will attach to the frame via friction-fit speaker grille connectors. [img] I...
Added project log discussion. http://forums.bit-tech.net/showthread.php?p=1143101#post1143101
Project 2nd wood case Hello. Project log for 2nd wood case project log I am busy working on this case as well as the first one, and also...
After finally figuring out why I couldn't reactivate my account (and then getting it reactivated) I am ready to post some pics of my next wood...
That's freaky. I went to St. X a long time ago, and I also made a wood case :) Seriously.
