Once the rush to buy 1366 & 1156 sockets levels out and a big seller like Dell begins to complain they are not selling as many desktops because...
So what finally happened with your Vandel switch? Did you get it to work ok? Was it a dead led inside the vandel switch from when you first bought...
Hi I have a Tagan 1300 watt Piperock and it has gone faulty. I've had it for about 10 months. I'm not sure what has gone faulty but the led fan...
Hi did you get the cables you needed sent to you by Nanopoint? They have good suppport at Nanopoint.
I'm not an electronics pro. But what about buying some 3.3 or 5 volt LED's from Maplins etc daisy chain them along a wire and run them all off a...
It's all colour of law give it up you will only be more out of pocket. Only person here with any chance is titanium angel as they (ebuyer) took...
Tagan PipeRock BZ1300 modular PSU with turn click metal connectors...Like them so much I've got 2. Best I've used so far.Before those I had a...
VERY VERY nice.Love the green look through the small side panel window.Was that clear or acid green colour acrylic u used? And how you managed to...
I,ve had a BIG NG fan controller and have to say once setup and running it,s amazing.Will control analog and PWM fans upto 18 fans if the watt per...
I've had a custom pc sub for 2 years now (best pc parts mag out i love it) and every other mag delivered by royal mail is damaged.Last one had the...
Some commenters got get the idea behind the PB but other comments on here show how little people understand and know the origins of the internet.....
There £155 Go figure
Hi yes thanks for the advice I will have no choice but to probably try the same as you and set the fan speed via a manual fan speed controller...
These "Akasa Vortex neo" so called quiter replacement performance fans which says on the box they are 4870 compatable "Which is NOT correct" in my...
Hi I thought u may like to see the Enzotech Type-7 Socket 1366 adaptor for the Enzotech Sapphire SCW-1 waterblocks...I bought it from the...
Hi Thanks Diosjenin, You've been a really great help to me thanks I appreciate it... I will stick with DDR3 1600MHZ, I found a place selling Geil...
Hi thanks so much for warning me on the volts 1.65 point..I did not know that.. Lucky for me I made this post and that you helped me out by...
Hi I have 2x1Gb sticks of Kingston Hyper X KHX14400D3K2/2GN DDR3 memory...I also have the Gigabyte Xtreme X58 core i7 motherboard.. I have seen...
Hi Shelley.. Here's a pic of the board I plan using the E7300 with an F-190HD.. The black heat sink is a little big. Here's the pic. [IMG]
Here's a quick update or not? Bought myself an Intel E7300 Core Duo for £92. I read on the forums it's a really good overclocking cpu. One of the...
