I do not need a top end card but something which can handle graphics better than onboard graphics
What about - ASUS GeForce GT 1030 2 GB GDDR5?
I am currently using the onboard graphics on my GIGABYTE H370 HD3 motherboard however an application I use for working on large image files needs...
Sorry, I should have mentioned this in my original post. I'll add it. I am not sure if computer A on a static IP, How do I find out?
The printer is already shared
Please excuse my ignorance when it comes to working with networks. I have 2 Windows 10 computers and I want to share a wired printer. The printer...
Many thanks for confirming
Many thanks That is helpful. As this will be a budget PC I will use - Intel Core i3-8100 Retail - (1151/Quad Core/3.60GHz/6MB/Coffee...
Could someone confirm that the the following are compatible with each other? Many thanks Motherboard - GIGABYTE H370 HD3 Socket...
Yes different USB ports & keyboard combinations have been tried.
I have no experience of linux
No wireless keyboards have been tried. Pressing ctrl-alt-del to reset the key states only partially worked. As soon as ctrl C is pressed the issue...
My computer has started to act if the control key is pressed when it isnt. The control key cannot be used as it should in all software. I have...
That is an idea, can you recommend one? - I don't know much about them. Thanks
Yes Canon drivers are installed
Unfortunately it doesn't
As far as I know, How can I double check? As I mentioned in my original post - I also noticed that there is no sharing tab in the printer...
Looks like it is Private network
I have my printer, Canon iP4850, connected to my Windows 10 machine via USB. I previously shared the printer with my Windows 7 computer and it...
Sorry I should have mentioned Sticky Keys off and alternative keyboard also tried
