Using ublock origin for desktop and YouTube Vanced for Android, not seeing any ads. Background play also works with Vanced. A neat trick for...
I think there was a lot of negativity towards the game upon it's release due to it's DRM
I run a Linux desktop at work with triple screens and dual gpus. Windows runs inside a VM under KVM so I can pass through the gaming graphics card...
Mine's just turned up, TK with blues for me. Nice to type on, although I'd have preferred browns if I was using it in an office due to the noise....
Yeah it's the 3 litre, I spend most my time on the motorway, actually pretty happy with the mpg. Had it over a year now, didn't get any frost on...
[IMG] Mah Z4 Roadster
Runs well. My RAM is broken and I'm currently saddled with 4GB, everything is smooth and on very high @1080p (i5/7970)
Second router could be a £20 TP-LINK N300 from Argos if you want a high street store
The second router isn't going to affect the broadband speed, it's mearly going to act as a wireless point and network switch. Maplins is a bit...
It's been mentioned by the dutchy, if you buy a second (cheap) wireless router, disabled DHCP. Then just run an ethernet cable between the two...
Your boot manager is on the wrong drive. I would mark the windows partition as active, reboot without the other disks using the windows recovery...
Thanks cookie :) here's the ad I listed in case you're interested: The Microserver is great, small footprint, low power, but excellent file...
Well a missing resistor certainly explains a lot! SMD heatgun with a fine tip would be my weapon of choice :) RAM was all good when I tested it in...
We had it booting briefly. Didn't think a CPU microcode update would be needed since the board was of Ivybridge era and the CPU was a Sandybridge
Hey guys. Went up to Oxford after work on Friday to give Oscar a hand in diagnosing things, as mentioned on the market. He covered my petrol, and...
+1
