I have a lexmark X1180 which is an all in one. i can still scan, but it now refuses to install let alone print. When i try to install it, no...
indeed, such a big drive should be partitioned.. even small drives should have its own page file partition also, because of partitioning,...
check out my sticky over at eocf, showing how stupidly out software (inc bios) is, and how to actually test rails...
added to favorites, ill check it out now n then, im the_cleaner-leon and yes, cs is still by far the most played, gota love it...
i currently have creative SBS560 5.1.. which is pretty much bottom of the barrel surround sound.. im rma'ing it as i get some strange sounds from...
http://www.kontraband.com/show/show.asp?ID=301&NEXTID=310&PREVID=0&DISPLAYORDER=&CAT=movies quicktime needed also quite funny.. but makes...
damn right, some shops/cafe's sell all 330ml cans @ like 80p - £1.. so thats about $2 for americans visiting must be bad enough having your...
when you consider advantage and future gain/compatibility.. amd takes it.. gaming, amd takes it, encoding.. P4 at the moment.. but like someone...
:thumb: thats so true.. the best point made yet... btw, i have no idea what all that 'In subtraction, to take a unit from the next larger...
whats your budget, and whats your video card cus theres no point in getting a monitor which has a native res of 1600x1200 if you have a crap...
its to do with ff most likely.. i find that clockin on a smily puts it at the end of my reply, no matter where i am within the text is.. its to do...
i see you have 2 80mm mounts in the back.. well.. theyr crap.. do this.. its what ive done and its worked quite well sizing up the cut...
just get the normal vga silencer rev 3.. and then just some ocz ramsinks.. it cools just the same as the new ones, but has littel to no problems...
this might help anyone wanting addition cooling on their ram.. though i think its something only neccessary when running ram at high freq/voltages...
do you have a good large work bench.. cus a router will need it btw.. i got my real dremel for £17.50, and it does 15,000 rpm to 33,000 rpm.....
look into light gates maybe
i had this problem.. and i knew nothing was shorting or overheating.. it turned out i had the cmos reset jumper set to reset, instead of normal.....
to discharge the caps.. i was told this very simple way.. take the plug out.. and turn on your pc.. i did it, and my pc actually went on for...
the most important rail on psu's these days is the 12v.. it runs the cpu.. all mechanical stuff.. etc
i would only make sense.. i mean, think of the consiquences of dust flating around inside your platters of valuable data.. every now and then...
