First option for me. NVMe SSDs are fine running a bit warm. If it's not enclosed then after-market cooling should only be a consideration if it...
I would suppose it the drying action is the same but it uses a heat pump in place of a conventional heating element. Hence the longer drying...
Manager: "Why are you in bed? You're meant to be working." SC dev: "...I am... I'm er... doing some R&D on bedsheet deformation" [lie gets out of...
[MEDIA]
That was 2012. Pastor Maldonado won the 5th in a Williams (still their last victory).
The worry is that now they know everyone knows their conventional threat is limited the only sabre they have left to rattle is their nukes.
[IMG]
Yep, that's just not true and hasn't been for a long time: https://www.ictsd.org/how-much-is-import-tax-from-hong-kong-to-uk/ Hong Kong may be a...
Old PC case. Cable management: Impossible Finger slicing: Inevitable
Talk was that Ukraine used a drone as a distraction over the Black Sea, having previously tested on response from ships to this action in other...
Released the day before the strike no less. Now that's what you call marketing. It's confirmed as being at the bottom of the black sea now btw:...
Even if it matters little, I'd still rather vote for who I think is the least worse than have my non-vote spread evenly amongst the lot of them.
Heavy metal :rock:
First thing I look for when buying a new printer is how expensive the compatible cartridges are and what the reviews of them are like. There is a...
Or failing that, when you land swing your knees round and try to roll with it.
Windows 11 doesn't have a never combine taskbar buttons option, so now all my open windows are now squeezed together in the middle/corner of the...
Correct :clap: (wrong number of dots, but I'll let it slide :happy:) I'm not thaaat petty :lol: O Lucky Man! is the second film in Lindsay...
No. [IMG]
