It's a shame you don't like Asus because they have the best i7 boards atm, but the Gigabyte GA-EX58-UD3R is a great overclocing board. I wouldn't...
I also agree with the above choice, but I will say if you haven't already bought the E8500, the E8400 is a better choice as it is £20 cheaper and...
If you want core i7 i would recomend the following f5rom www.scan.co.uk: Asus TA-861 Black midi case - £18.35(cheap nothing flashy) Be Quiet...
If your rig is for gaming then the best chip is the E8400, as it produces a higher FPS than the other 3, at stock and overclocked.
No the 896MB is dedicated graphics memory that the system can't utilise other than for graphics processes. So the system will use the 3GB of ram...
My wife plays The Sims 3 on max settings on an old core 2 duo E6550, with no problems. The following comes in at £328.74 Amd Phenom II X2...
A core i7 set up is possible on a budget of £600, if you only need the bare minimum. From www.scan.co.uk as follows: Intel i7 920 D0 -...
