A kid like you wouldn't be able to recognize maturity... as for the rest, leave it! It seems as your single threaded neuron can't handle it!
The whole story is about Intel's past doing and you rant about some lame progress that Intel needed badly so it wouldn't lose market share! Even...
Were you high all this time?... to what has happened during the P4 era has just been given a verdict: €1.06 billion fine! And I was always...
If an OEM is required to fulfill an order of x chips, but AMD can't manage to supply enough, how do you think that OEM can stay in business? Its...
And when was that?
A lot of offices switched from desktops to notebooks so imagine the need for them to work, even if they are private property of each individual,...
You don't need to count the components... the version with the flimsy cooler is the weak one and the version with the exhaust cooler is the...
Gigabyte's 4770 is a TOTAL FAIL! Edit: so is ASUS! The exact same ... pile of you know what!
If we knew how much IBM was going to pay for Sun... we might have had an idea.
That practice isn't allowed for well established businesses... only for smaller ones!
Intel is also under investigation in Korea and Japan for the same reasons... in the US the FTC and the state of New York have their own cases as...
Core i7 920 + Intel Smackover + GTX 280 got 103W in idle??? That's low! Core i7 940 got the same number in other tests... No here comes the...
9.2 are for legacy hardware.
"the GPU will become indispensable" Yeah... looking forward to AMD's Bulldozer and Intel's Westmere.
Linux ? Its market jumping to 20%? ROFL! I will buy 7... but as was said, as long as paying customers don't have to support the problems that...
That was before their stocks degraded to the current levels... and as the articles says, "AMD is now focusing its efforts on developing CPUs with...
I see.. the only issue is that the fix requires CnQ to be disabled which would affect the power draw in real usage situations reducing DrMOS's...
Think of this... a GPU on CPU that works in WDDM (Windows) but in games, you can switch to dedicated graphics... that's the idea. Now, since the...
So I would still like that bit of info I posted about above... please!
Quick question... does the ASUS board have the SATA performance issue as well or it's limited just to the MSI board?
