86% for a mouse with a bad scroll wheel and buttons that are too hard to press? Maybe the bit-tech writers should read each others articles, there...
I guess this is the end of bit-tech, especially when you get an editor who's been in charge of Micro Mart taking over the reins. No offence, but...
It's got a pair of 3.5mm jacks, just not clear from the pictures as some clever person plugged the end that goes into the PC into the headset... :p
No, you only need a battery IF and when you use ANC and if you look carefully, there's a switch for enabling and disabling ANC. So take a chill...
Uhm, I have a pair and the bass is the one thing missing in this headset, don't get me wrong, the overall sound quality is very good, but...
Considering the chipset price difference is less than US$5, this board should be cheaper than what it's retailing for...
It's July, why are you lot still recommending P67 boards with Z68 boards cost just about the same?
Guys, get a different board, both Asus, Gigabyte and MSI have board with an external clock gen that allows you to overclock the APU's by quite...
Wow... don't think I've ever had a system for over two years, but then again, when you upgrade them bit by bit, it's hard to tell how long a...
Try using IE, it doesn't seem to work well in other browsers fwiw.... As for cracking this one, there's one very simple trick, upgrades. ;)
Managed to beat it in the end. FYI, there are two different ways of getting to 36k, one starts with UEFI ;)
If you're using an encrypted VPN connection, then no, they won't be able to see what you download. This is why encrypted VPN services in Sweden...
I guess it'll be good business for the various VPN services on offer that hides your IP address...
It's not an April fools, this have been out for a few days already. On top of that the LGA-2011 CPUs will have PCI Express 3.0 support and more...
Wow, what a sloppy review, what's going on bit-tech? You're really losing your touch as a reliable source for good reviews :(
That might be a bit ott, but I'll agree that he's not the smartest or most interesting person to talk to I've ever meet... actually, he's outright...
You lot do know that Asus and Assrock are no longer part of the same company right? Asus is, well Asus and Assrock is part of Pegatron who is no...
Do note that this is an older PCI card, so it might very well not apply to PCI Express based NICs, nor the various kinds built into the...
It's not Gigabyte's first gaming keyboard, they launched the K8000 in 2008 http://www.gigabyte.us/press-center/news-page.aspx?nid=-597 The K8100...
Well, while I'm pointing things out, it might be worth noting that the High Point Rocket 620 also uses the Marvell 9128 controller. I'm amazed at...
