The batteries say their standard current is 0.07 mA
I have a little battery powered LED circuit that I want to plug into a molex 5v supply from my PSU. How many resistors, and of what resistance,...
It had about a half Ohm when I set it to the 1k setting. Hm... I need to convert from 5 volts to 3 volts, know how I can?
Oh, yep, the little RAM-gripper-pin thingies are up.
Ok, I put it at the 10 Ohms setting, and the pointer was at "10" when I touched the probes to the leads on the resistor... so it's a 10 Ohm resistor?
It's an analog multimeter, not digital.
I'm talking to myself, whee ;/
I don't see RAM either.
No sound card? Onboard sound or what?
I have here a Radioshack multimeter, and I want to check the resistance in Ohms of a resistor I have here. These are the settings on the...
I'm putting it near the plastic part of an LED by the way(the fibre optic won't be drilled into it, I don't feel like doing that fine-work)
Yea, but would it glow?
I'm looking to do some glowing thingies with flashing LEDs and fiber optic lines in my case(stylish!) and I was wondering how I could do it....
http://www.bit-tech.net/article/68/ How do I find the mA rated current? I can't figure out what that would be ;/
So the red wire from the molex is a 5 volt positive current, right? Then the negative current goes through the black wire? Just making sure I...
Woo, 1.5 http://www.microbattery.com/SAC.html
Oh, I think they're 1 volt... http://www.blkfeather.com/productinfo.aspx?productid=66&categoryid=21&startpage=1 So that means they're 2 volts...
Err, it says "AG(S, I think, maybe a 9 or a 3, though... smudged on both batteries ;/) PK Button Cell" on it.
Err, I messed around with our Radioshack multitester but couldn't figure out how to find the power the batteries gave off. It had all kinds of...
Actually, I'm planning on using fiber-optics from the area of the LED's to different blades on my side-fan, I think that since it's a dual-LED...
