creating flames The way that most automotive paint shop lay down flames is with 1/4 inch masking tape to lay down the design and then mask the...
I currently have two computers in wood cases, but the boxes were premade out of MDF, they are in 12" cubes. I haven't had a problem yet and one is...
I would suggest not submersing HDs in that stuff, or at least put tubes on the breather holes. Cray used to use that stuff to cool the systems I...
Yup , next let's remove all satilites, no DirectTv( or dish network ) oops, radio/TV stations have to go down next. oh boy ... the Sun, lets just...
I figured as much, you're one of those ppl from across the "link". /me is in comp sci.
Sorry off topic. ND?? GFK perchance? I goto school at UND that looks alot like GFK. BTW awesome paint job
Debian is bay far my favorite distro, the package managment is great (beat rpms into the ground). I have yet to try gentoo mainly because I do not...
Awesome project, I hope you get it built. Have you checked Digikey for the parts? If not, here's a link Hall effect sensor I did not know...
not bad, but the last time I got stuck was with a Ford F-250 4x4 highboy , that sucks. I had to have a tractor come and pull me out.
