Twice the length from its center to one end. :)
just checking, diddnt want to help anyone elses score :D , finished one and on 365/500 of the second, getting there slowly
''sidney is running his at 2500Mhz with 2.2v'' you have a good memory m8 :) atually though i am back down to 2v, the 2.2 was to try and get...
1440, nah do what i did and slap a mg metro turbo lump in it, you wont be able to drive it without smiling :D i even prefer it to my little...
just joined, running as we i type, team number is 33346 right?
my xp2500 running at 2500 (12.5x200) has a 5v line voltage of 4.97 as well straingley enough, no probs here.
i can see them, it looks like he is trying to back a car up over his case
very nice so far m8, cant wait to see it all in the case, like you using your pc 'caseless' just with the mobo tray lol :thumb:
first run [IMG] 2500+ barton Radeon 9800 pro 512mb ram
2500+ barton Radeon 9800 pro 512 meg 3200 (2x256 chips) anything else just ask.
thought i would join in :D [IMG]
off the top of my head, on the machine u want to access go to control panel, system, then the remote tab and check the enable users to remotly...
cheers :thumb:
well i have done it, bought a Powercolour Radeon 9800 pro, 128 meg version though, seamed a lot more money just to get the extra 128 on board....
you will being up tecnical problems, its ok though ebuyer is in the states as well, Linksys ProConnect Integrated 2port KVM Switch $33.50...
allright i lied, the micro kvm is £23.49 from ebuyer now, link to kvm :worried:
for a kvm, ebuyer.com had micro ones to control 2 pc's for about £15, if you are running xp and have both machines on a lan you can use remote...
after searching for a while for a new card for around £350 my choice is between a nvidia 5900 256mb ultra and a ati radeon 9800 pro 256mb. as i...
i am going now as i have paid up, may be a good idea on a bit-tech clan allthough deciding on which game section to play under maybe a prob, at...
http://www.multiplay.co.uk/i18/
