Stevey G did you find the resistor valuse needed for white ? Its been a while and Im back working on the robot again and I am hoping we found...
Ok I did some kung fu figuring out the exponential curves for each color and the above numbers are accurate as is practical for the resistors...
the ones I have are off of LSdiodes.com wow so it is a function of the pwm I have to get , so it is important though that the brightnesses in...
its all good man I have moments like that all the time . :confused: so do you think i got the voltage values right for the mcds being equal...
ok your diagram makes sense, IM going to do some math to try to determine how to set the resistors up so that I have the max red brightness...
Ok I see what you mean about needing resistors and im seeing that this aspect may make what Im wanting to do impossible. 1 the resistor values...
a bit confused about some details I plan or embedding them in pieces of sanded plastic so that the plastic milky edges are illuminated, 6...
Ill have to look at lsdiodes specs for the leds im buying , I do plan on doing PWM for the leds so never in any instance would the whole array...
OK here is my schematic : conststructive criticism?? here is the schematic , I agree in advance it needs work I know I need to add a crystal...
Sorry to hear about your laptop HDD man , but I think you have the right idea to Paraphrase an old cyberpunk novel: "Never forget: Dead is...
one other thing , just to set the tone and give you an idea of the type of k-9 im building , if youve ever the seen farscape tv series on the Sci...
Good question , The K-9 in the doctor who series was kind of a gun metal grey color. I have seen cartoons and comicbooks where he is drawn to...
Javadog, I have been looking at this tool because of my project just might require some soldering , ( lol do you concour?) I read the pdf and...
One of my sources of inspiration Queues Music: Its Rare that someone does a project that is so incredibly cool to have us drooling like this....
I know carbon fiber is expensive if you buy it already molded in panels , Im going to be doing that on the flat surfaces and epoxying the edges...
one word answer: Affirmative!! heres some drawings I made in paintshop: [img] and a pic of my cardboard reference model i made to get...
Hello all , been lurking here and Im ready to start talking about my project. I am building a replica of the k-9 robot from the BBC show Doctor...
Thanks a bunch man!!! Ive got a preliminary schematic for the pic 16lf877 that seems to cover it all , but I think im going to check into the...
Ok no one has responded.... specialk, IM about ready to start ordering stuff and building , im wondering if I can make 4 versions of the led...
Does anyone know the answer to my previous question ? anyone been able to get a perfect seal with weld-on ? no bubbles or cracks or voids?...
