This thread should be flagged as Steampunk Porn... Just Saying...
Indeed, it is the same project I do beleive. Great job anywho!
It is Ebony. That is the natural color of the wood, and is extremely expensive. It is also pretty hard to find pieces longer than 2 feet ><....
No dont touch it sweety. You know that company probably makes Head Stones for those who touch that holy case. GOOD GRACIOUS. Tips to you sir,...
Are you selling as a; Complete System/ Case/ Case+Watercooling? Why man you've done so much work.
Gun Oil once applied, does not leave the surface oily as some may think. It actually binds it self to the metal and prevents rust from occuring....
TIP: GUN OIL. Use gun oil, which is an Anti-Rust solution that you apply to the metal directly. It soaks (Yes into metal) in and helps prevent...
If you are still unsure of the Epoxy/Resin buy a small sample that will give you a 3/8" thickness on a 6 x 6 piece of Aluminum. However you will...
Thacrudd, Exactly what I proposed. LOL Well it isn't exactly rubbery, I have always thought of it that way. But yes you are right it is very...
You could also use a Restraunt style epoxy, that gives the appearance of glass. You take your aluminum and make a wall the thickness of your...
I'll take some pics later this evening to show you some Aluminum rods that I had polished for my bloodwood computer. I have yet to re polish them...
I'm going to solve all your problems, LOL, make a brass, and aluminum front; as well as brass, and aluminum feet. Swap them out at your will.There...
: APPLAUDS LOUDLY : This is some of the greatest Aluminum Channel and Plate work I have seen in along time. Every piece is looks elegant, as...
Ok just so you know, when I viewed the first set of pics, I THOUGHT IT WAS A LIGHT PINK. Must be taking the picture in a darker type room with a...
Sorry for your loss. Hope you get what you want in the future. If you want it done right, please, do it yourself Regards
IMHO, Marcus did a fantastic job "FOR YOU". It also sounds as if he has a bit of extra projects going on behind this one as well. Everyone has...
Wood Computer: WD 500 GB WD 1 TB x2 raid Seagate 120 Maxtor 160 WD 150 GB Raptor (Solo :( its partner fried) Which Brings me to a grand total...
Yeah... it is near to impossible to get vent to work in linux.. /sigh but... i am going to keep trying... i finally got the push button to work in...
So I have searched the WEB through and through... and have not found anything that will allow me to utilize ventrilo in a functional manner. I...
As long as it has the HUGHES 500 in it i will be just fine... I love that helicopter!
