Alright...have been gaming for 4hrs continuously without any problems right now...looks like its a software issue..thanks for the advice =)
alright, did a reinstall of windows and installed the latest 331.83 drivers, will post an update after restoring my games =)
the full complete reset means reinstalling windows?
Hi Guys, just upgraded my rig to Win 8.1 Pro WMC few days ago, installation went fine, everything was fine until the PC started to shut off...
thanks for the info....guess is time for an upgrade soon =)
Taniniver...the monitor goes to sleep the moment i turn on the pc Picarro: the old card is a nvidia 9300gs btw..sorry for the inactivity these...
could it be the pcie x16 1.0 slot on the motherboard not able to recognize the card? but as far as i know pcie 3.0 is backwards compatible
we've changed the psu to a silverstone 500W psu in the Pavillion
Went to buy this new card with my friend at a pc shop yesterday. So we went on to install this card in his hp pavillion a6665d , we replaced the...
faugusztin: can you tell me ur bios setting? maybe it will help me to solve this problem
enabled
my settings are Initiate Graphic Adapter PCIE/PCI iGPU Memory 64M Render Standby Enabled iGPU Multi-Monitor Enabled tried to install vritu but...
ok, i'm using razer arctosa keyboard and a deathadder...i've installed the latest intel chipset drivers and it worked for the last 3 days fine...
it says no discrete gpu found...but something is funny...no i cant run the display output from the 570...nothing is showing up...but the card...
i cant even install virtu...i always have this issue with my board...sometimes the 570 has signal and sometimes the onboard graphics has signal...
ya pete ok i'll try, i'm not using virtu, directly using my GTX 570(latest 275.33 drivers installed)
everything seems normal in task manager with system idle process having 85-99% of cpu usage
Remember last time i had a thread saying my P8Z68-v pro mobo had issues? I took the board back and the seller tested that both my i5 2500K and the...
Same feeling with ya goodbytes
Ya, i tested it outside the case and got the same problem
