It looks like the paint is seperating. This could be caused by three things :- 1) A reaction between the paint and the orginal paint on the...
Right Had a good weekend so I thought I would update this early today. I Drilled the rivets out for the top of the case and promptly removed...
Another suggestion when painting, Put the can of paint into a bowl of hot water (not boiling!!) something that is hot enough but you can stand to...
If your fitting water cooling how about turning the washing machine window into a resevoir? I am sure with your uber uber skills that you can...
I dont know if anyone has ever seen this but on the back of the AOL cd there is actually a warning message telling you that it will mess up the...
Aha, painting. I know this one. kinda anyway. Prepare the entire area with a low grit sand paper, something like 240-800 maximum. You will...
I dont think i will be able to look at a PC again :waah: I am going to have nightmares for weeks. This is so cool :clap: :clap:
I have a few old laptop keyboard knocking about and not having anything to do with them I was wondering if it was possible to mod the little...
I have already done some stuff to this case but thought I would update slowly to give me time to keep slightly ahead. The main side panel...
Hi, This is my very first Mod, this means that I have never taken a dremel or other tool in anger to my pc (or for fun) Just a quick word to...
You could use a can of compressed air or a hoover on blow???? :idea: I have done both of these before. Do not do it in a confined space...
Did you check out this bit-tech article?? http://www.bit-tech.net/article/72/1 This guy made a lovely little clear box case and used some...
I would reccomend the clevo from the range above. Clevo build laptops that are kind of a barebones for all kinds of companies (rumoured to...
Try this. Check under all the little rubbery bits, and/or stick on covers for all the screws on the screen part only, remove these. Then...
Hi This is my first post and thought I would make it a good one. Most laptops use some sort of proprietry system to run the screens. So it is...
