I would add a +1 to the request for technical overviews of games. Being both a gamer and a builder of rigs to play those games on both are of...
Gah, totally torn now. I've been waiting for these cards to come out in the hope that they would be affordable - my 4890 desperately needs putting...
I was waiting for the numbers on Southern Islands before deciding on what to replace my dying 4890 with, something which will last a while and let...
I found on my old Gigabyte P35 board that I could only boot from DVD with the optical drive in IDE mode, however I have had no such problems with...
@TSDAdam I used Acronis to copy my boot partition across to the new drive, worked like a charm but then that partition was actually smaller than...
Do your research on the drive you want to get, especially check the support forums for problems and more importantly if they have been resolved....
Lol you're right, there's no need to upgrade at all yet. I've been so dazzled by the upgrade from E8400 -> 2500k, for me it's made an epic...
eBuyer has a deal on factory overclocked GTX560s at the moment - £180 for the 900MHz version. I was considering this as an upgrade to my HD4890 to...
First issue: in the BIOS the power saving options don't kick in so it will be running at full speed. Once you get into Windows then it will clock...
Indeed The cables that came with the board
Yet more success. Now that we isolated either Windows itself or the SSD as the problem I tried playing with the SATA ports. It turns out that the...
Success! I can enable XMP and set the CPU ratio to 45 and boot into Linux Mint from CD. So, what now? Is it a case of ditching the SSD :jawdrop:?
I left it for an hour once just in case, although I haven't done so recently. A good thought though, and hopefully one which I might be able to...
Definitely worth a go, thanks, I'll try it tonight. It is rock solid when at stock speeds and I haven't yet experienced any random crashes...
I also found this thanks to someone on the Asus forum - http://hardforum.com/showthread.php?t=1578110 It didn't help me but it's a great...
OK here's the settings for a completely basic overclock up to (gasp) 3.8GHz [IMG] [IMG] [IMG] [IMG] Basically everything is set to the...
I would guess that it's because they would be using 4x4Gb sticks. I've read that using all four memory slots can indeed limit your overclocking...
Sure, it's worth a go. I'll try and upload some stuff tonight.
@faugusztin The specific Auto/XMP/Manual setting I am talking about on the Asus board just gives you access to the BCLK and memory frequencies...
I'm thinking it must be the board as well, I've tried downclocking already with the same results. Guess I'll get onto Asus tech support and...
