I have a QPac and I would certainly not trust the handle to hold if used repeatedly.
I've been trying to get XP to boot from an USB stick and the problem remains. The only know workaround is to make a ram-disk and then load windows...
First you laugh at my post for not answering the OP (just pointing out that IF he had a table router straight edges wouldn't be a problem) and...
If you have an uneven edge and have access to a table router with a fence then just use the router to straighten the edge? Problem solved. :dremel:
Sadly many new games lately have fallen short of what they might have become. Like Just Cause, The Guild 2, Darkstar One to mention a few. It...
Why not keep going with the line from the koa piece on the side and make that flow to the front. Would tie the front together with the sides. And...
Not to be rude or anything but if you read the first post in this thread you'll get answers to your questions... That said, looks like an...
When the car is on, I am in the car and can control the temperature quite well with the fans of the car. This application is for when I'm not in...
You could probably build a circut that can't be switched if there is current flowing to one of the HD's (to prevent hot-swapping). With a...
No luck in finding a source for that chip here either. I think I'll keep it simple and just make a fan turn on at a certain temp instead.
An increase in speed in relation to the temperature certainly wouldn't hurt. Thanks for the replies, I'll see what I come up with. The PVM one...
What would be the easiest (and cheapest) way to make a fan start at a set temperature. I want to put one in the back of the car to circulate the...
Humming is there always when I try to use the scart cable to transfer sound. I tried to connect via RCA cables directly to the amp and now the...
Perhaps you can point me in the right direction to solve a problem I have with my newly created "Media PC". When I purchased new parts for my...
I totally agree about the insane length some people go to do multi-function devices. The only good way I see to do it is to do it modular. Have...
It seems that's a bit out of my price-range as I can get a keyboard with media-keys for less than 20 Euro and that controller with shipping would...
I'd love to see some pictures of it (hint hint). :)
You could actually hack off half they keyboard and fold the membrane (though I would be careful about that since they can be quite fragile,...
I'm looking for a way to make external keys (not linked to my keyboard) work as media keys in windows. So I think that program is not what I am...
Oooh... If I had the know-how and the materials I would do things in fiberglass all the time. As for ideas for your case, how about making an...
