The Xice 8/6 tubing would be the right size but it isnt very flexible.
When I posted on that thread in the pclincs forum I had not been told that over-clock had taken it over. As far as I was aware the shop was dead...
Really good demo.Im getting the game for sure !! [IMG]
eh ?
Yeah everything used to be in the sheffield area but theres a lot more round here now.
Very Nice :thumb:
As far as I know the Maze 4 GPU block should fit but you will need to get some ramsinks.
Ok maybe the 1250 is a better idea with the RBX :duh: Yeah I carnt see why you need tubing coming into the case at all it should all fit into...
They might have glued it in place to stop people messing with it but I have never used waterchill kits so im unsure. You might want to try running...
I think the sarcasm is off the scale here. How did you manage to use 8 meters of tubing?
I guess its caused by a damaged seal. To take it apart twist the blue cap to the left and it should come off easily. The black part behind that...
Yes it will be better than the Asetek WaterChill but that 1/2" tubing will not fit through a blanking plate, neither will 3/8". Why do you need it...
We have reduced our price to £189.99 due to the recent Xice Price cuts. Paul, WaterCoolingShop.com
http://www.watercoolingshop.com/catalog/product_info.php?products_id=105
Most AMD Gigabyte mobo's dont have the mounting holes. Im using the DFI infinity, its a bit cheaper than the lan party and Its great for...
Looking good!! Whens it going into a case ?
I’ve tried the Maze4 Gpu block on the AIW and it definitely doesn’t fit. If your wanting to use DangerDen this one will work....
I voltmodded one of the cards and it would do 480MHz when watercooled. It would probably have gone close to 500 if I had pushed the voltage a...
Ive had 6 9800se aiw's in total they were not hercules branded but they were exactly the same board. - 3 of them modded to pro 100% with no...
Sorry :worried:
