You can get a router that supports QOS (Quality Of Service) and set your IP with the highest QOS. That means if she is downloading something...
I never did really like d-link. Here are a few things you can try: 1) Upgrade the firmware on your router. 2) Forward incoming ports...
This ARP traffic has increased due to the recent RPC worms like Blaster and welch. Since these worms go and run a ping sweeps on random subnets...
Bah, Linksys.
[IMG] [IMG]
let me let you on a little insider information about Kevin; First off, he was never as good as people made him out to be. If he was so good he...
noobs.
YOU LOOSE! There is no such thing as an OC-255. Types of Optical Carrier connections: OC-1 52 Mbps OC-3 155 Mbps OC-48 2.5 Gbps...
Cant see the other rack but all on there is my CCIE Lab I run a few personal webservers, servers, etc... Then several of those are connected to...
Get a router, I don't belive in sharing connections with 1 computer acting as a gateway router. #1: Free up CPU usage #2: Routers don't require...
I win! Fulll T1 (1.544Mbps) Pipe in my house. room requires a window AC unit running on 60 Degres 24/7. [IMG] :)
Its not one of the songs thats in the soundtrack. It sounds a bit like chanting, etc...
Dunno, I can tell you this much. Travis County cops are real hard assess
Anyone know the name of that song that was in the triple x trailer? It's the part that sounds like some opera something music. I can't explain...
The the ports 4747 and where it asks for the server IP you enter the ip address of the machine that the game is running on. (your machines LAN ip...
Oh yeah? I was not aware of that. I don't know if I am going to contue to take my written this week because I have family coming in town and I...
Actually you could set the server to be a DHCP relay agent for the router. But, If you just need it for DHCP that would not be the way to go. What...
But just to be on the safe side with him he should go with a standard 8 bit subnet. Better safe then sorry. I understand what you are saying, but...
IM Sorry, lemme clarify that. "Ports" on switches using Full Duplex have CSMA/CD Disabled. But, if a port is running half then its enabled......
