yea, i would check the battery out. Maybe its out.
if you lookin for a cheap am2 mobo. ecs geforce6100sm BABY!! <-------overclocked 3800x2 and still running... :rock: too bad it has only 2...
Thanks. Using 3 80mm fans and a 120mm fan in a cheap powamax case. ok, i guess i should not disable the cool n quiet then. Hmm...the...
oh yeah, should i disable cool n quiet feature in the bios??
yup. cpu is dead. giving voltage to a cpu without a heatsink. its dead.
yea dude. thanks for the help man. :rock: I got it set at 1.3 :thumb: cpu temp is ranging from 25 to 29c <---from the bios [IMG]
i believe i cant anymore. 1.3 volt was the last choice :waah: :waah:
[IMG] ACHIEVED 2.4GHZ!!!!!!! Now am tryin to get windows to boot over 2.4ghz, having problems booting. I upped the voltage to give it...
hmmm...werid driver issue? did u put everything in the bios to default??
well lookahere....its a fellow cb7tuner. :) nice set up. good luck on the build :thumb:
hey guys, i benchmarkered my system wit a x4 HTT, and i posted a lower score on PCmark04 wit a score of 53XX i had a score of 555X when the...
deadend, no option to raise the voltage. :waah: :waah: ... well 2.3ghz is not bad of a overclock, plus on a cheapo mobo...HELL YEA!!! :D...
[IMG] right now i put it at x4 from x3. voltage has been the same from stock. how do i raise it up?? [IMG] ^my memory options in the...
yea. right now its set at x3. ill bump it up to 4x right now. wat about the memory?? right now, i cant get windows to boot anything over...
okay. i dropped the HTT from auto to 3x. :p :naughty: [IMG] is the HTT too low?? bump to 4x? OR is that okay?? [IMG] okay^??/
will do that. thanks
yea. i see that you gotten up to 2.4ghz how do i get my HTT dropped?? How can i change my memory speed? I dont know if i can change my memory....
1gb pc5300 ram ecs geforce6100 mobo 430 watt thermaltake PSU what else to know??
<----noob memory divider??
[IMG] i got it up to 2300 mhz.. :clap: i got it to boot up at 2350mhz but during the load up it gives me a windows error, blue screen...
