I forgot to update my work here :blush: I hadn't do much more on the case, but the fotos talk by theirselfs [IMG] Cutted the hole for cdrom...
I thought better and I will do a radiator that fill the rigth side of the case :) I made my control panel [IMG] [IMG] More to come...
Thanks for the explanation and comments ;) I don't now exactily how much it cost because I bought it a while ago and it was mom that paid :D...
You are talking about the wheels, right?(sorry my english is not the best) I found the caster(wheels) in AKI , a bricolage supermarket. Sorry...
The case will be all painted ;) The case mounted again after being painted [IMG] I made a top window to a reservoir :dremel: [IMG]...
This is my first "serious" mod. It all started when I found a case in the garbage and bring it to my house with a lot of ideas to case :dremel:...
One more tuga :p Peterwolf your mod is excelent :thumb: I don't like the aluminium face plates that you put on your case, but the case is...
The lcd is an HD44780 from seiko. I know that i could control the backlight brightness by software but i want control by two buttons for a mod...
It's a LED backligth. What i want is, instead of turn a variable resistor, have two buttons one for increase and other decrease the backlight....
I want to control my lcd backlight by two buttons, + and - but i don't know if is it possible, i think so. For example for mobilephones or...
try this eheim-mod with the time the ceramic axle starts to be worn out itself and creates a recess(?) , that starts to make noise. ;)
NIce man :thumb: You could do in the port of the chieftec the reservoir. [IMG] It's an idea but congratulations :clap:
I only want to link the lcd to pc, it may be by parallel, serial or usb. I think taht lcd have the controller, but I have the rest of the gameboy...
I have an lcd from a GB and I would like to link the lcd to the parallel port, but I dont know if I can or if is it possible. I found this...
http://www.oc-zone.com/modules.php?name=Articles&rop=conteudo&id=47 It is in Portuguese but if you have any doubt use babelfish or ask me. ;)
I like the idea of a LCd inside a case but something like this: [IMG] [IMG] http://www.globaldata.pt/forum/viewtopic.php?t=24277 :thumb:
Thankx! :D :p
Well you could try to built a phase-change colling.It is cheap than prometeia, and have the same results. The site is in portuguese but you could...
