I tried the Crashfree BIOS before I got the new bios chip with no luck. Tried it again there and still the same. I also tried the Phoenix Utillity...
I'm afraid that hasn't worked either :sigh: I'm not keen on RMAing it to Asus as I've heard it can be a pain. Any other suggestions? Thanks!
Yes I have the box and packaging. I'll contact Asus and see what they say. Cheers for such a fast reply!
I think RMAing is out of the question as the board was purchased from a friend.
Hi all, To keep it simple, I went to upgrade my bios using Asus' EZFlash 2 (something I've had no problem using before). After it completed I...
See if Coolermiester can give you any info on that cooler. He used one in his last Project.
Stick "Kao" in then :P
I've had that and it was a dodgy stick of RAM. Had to replace it.
A simply stunning piece of craftsmanship.
Looks great! Just a quick idea. I'd give the sides of the acrylic a sand down. Will make the edges much more cleaner and less bumpy. :thumb:
Likewise. I've been on 2Fort and this enemy sniper was picking off everyone that came out. Even fully cloaked spy's as i tried it myself.
Did the latest update not allow you to screenshot the scoreboard after the map has ended? and..... try this :P...
Yeh mate the prices there are shocking. I mean £23 for a SATA to IDE converter and £5 for one SATA cable. They should be wearing black balaclavas...
I just got an A.C Ryan Blackfire and Lian Li HDD Bay myself a week ago. Must say they're superb so a good purchase there for you :thumb: Looks...
Nope sorry :(
Yeh. Hope you get it sorted out :thumb:
I'm not sure tbh. I have a 7000 with a blue LED fan. Not sure where you could buy one sorry. I'm in the UK and it looks like your over the pond...
The LED's in it gave up the ghost so the Zalman UK Representative sent me out a new fan.
Afraid not. I can see the LED's through the clear plastic. Theres two of them. But i can see no way to get at them without opening up the fan.
Ehm slight problem i've just found. The way Zalman have held the fan inplace, if you were to take it apart it would not go back together. In order...
