Last night was undercoating doors and painting door frames and skirting boards, I wouldn't mind but it was not even my house....... tonight...
So i guess i'd best put post 50 in here then, seeing as I will be working on this over the weekend..... :dremel: I have been told i'm not...
I'm inclined to agree with you there olv, my 17" runs 1280 and fits perfectly but looks out of place on the 19" as for the chioce of TFT,...
DVD Burner? me got 2 :D so we can burn whatever needed. choosing a tft as well, you are mr poll this week :rock: and methinks you have too...
They were real expensive when I wanted one a while back, think Sc0rian picked it up for about £106 which is less than the CM Wavemaster so I think...
cube cube cube cube go for the CUBE! I always wanted one of them, enough room to build in network hub/switch and a sff firewall and prolly enough...
try these - http://www.xcase.co.uk/acatalog/index.html they do all sorts of cases from the plain vanilla to the bizarre!
Hey Man, that drive is looking sweet as, like it a lot, thanks for the mention btw but didn't do that much, a bit o braiding/shoppin etc :D oh...
:D I do indeed mean version 1. have a new box with 1.3 loaded but going to wait for 1.4 now as like you say its nearly out (that n the fact that...
Wonder what the 'yet to be announced' product will be.... :eyebrow:
Anyone Else been emailed this yet? As you may have noticed, there has been a slight delay in your Novell Linux Technical Resource DVD kit...
:D that was on the webpage with the order confirmation, I got the same information as you in the e-mail confirmation... if that makes sense.... :D
I have been running IPCop ver 1.0 for over a year now, Running on an Old PII 300,128 Mb Ram and a 2.5Gb Drive. To give you an Idea of what it...
:D Cheers for the mail sc0rian :D I'm glad you have so much time on your hands to find these little gems :thumb: Also UK based ordered...
:waah: I can Add to My List :waah: I have been PC less for almost a week. PCWorld SITECOM Modem. = AVOID Killed my Epox KT600 Mobo, which...
TechFlex from Fleetwood Computers dfk - I cheated mate I bought both male and female molex removal tools click in pop of x4 one done takes...
Sorry for the delay, Have my cousin over for a long weekend, will be in and out all weekend, My MSN is mcduquesne@hotmail.com DP.
One thing I can think of, if you move the lower of your 2 CD Drives by 0ne bay you should be able to use the space in between to 'conceal' some of...
The Black one I have is Gloss but not smooth, orange peel effect, needs stripping and repaining for a true smooth effect. The Aopen Black Pearl...
Mine just borxed on me :-( Just been searching on the forums for any info on these, My Spinpoint just demolished my entire OS, been running for...
