[OFF TOPIC] Ha ha, i think all of my DCs have had that at one time or another. Its usually caused by a build up of dust and general grime on...
The 360 version of Call of Duty 2 recieved a 7 from Edge aswell. I'm rather dissapointed there are so many poor conversions of current-gen...
Bah, seems there's no video available now.
I haven't watched the movie yet but that sounds an awfull lot like Chrono Trigger from the SNES days. May not be a bad thing considering that...
Fortunately not, it seems M$ is being pretty reasonable about it.
Dunno if that will work or not. I'm using a Creative Labs 6.1 set up and would still want to use it for PC games. I need to see if I can plug it...
You can connect via your PC and download then burn the emulators to a cd. Alternatively you can send off for a premade CD if you don't mind paying...
Yep, but Dead or Alive 3 IS backwards compatible... I don't believe the games I listed, which were all big sellers, have been excluded because...
For you guys connecting a 360 to your regular PC monitor, how do you intend to get sound out of the 360, presuming your monitor doesn't have built...
Linkage Its a bit of an odd list, yes list, not "Chart" ;) Anyway, there's some big games missing, Project gotham Series, Soul Calibur 2,...
For some reason with my DFI SLI-DR, 3700 SD, and 2GB G skill 4800, my DVD drive randomly doesn't work. Every now and then it will just make...
Ta, i'll take a look and see if I can get this stuff fixed, probably still won't be able to use it through my KVM though :(
I have one of these too but I don't use it as it seems to be a bit "iffy". So far I have found two games that don't work with it at all....
Nope, its true that kids can't buy GTA or other "18" rated games but I am constantly seeing their parents buying them for their kids seemingly...
You shouldn't think of it as trying to emulate the way light is in the real world. It is far more like the glossy sheen you have on hollywood...
Not to reach a new rank there aren't. Just be patient, it takes a lot of points to reach corporal, you need about 10,000, from the 1000 you need...
They aren't "better" just "different". For exemple the medics L85 unlockable is more accurate than the regular weapon but has a rather...
You need 10,000 for the Corporal Rank, which is next along for you. After that its 25,000, then 50,000 :jawdrop: If you haven't done so go...
You can't login because EA's account server has been hacked, apparently... It was said last night that it would be down for 24 hours, I haven't...
Anyone got BF2 to run at 1280 x 1024 yet? Altering .con files seems to cause a crash when the game loads...
