There's nothing that says you have to make it out of metal, you know. Plexi cuts easily, cements together, and can be bent.
You need a ruler, a tape measure, a t-square, a level . . . Seriously, you need to measure like a madman! Take your time, but stay motivated!...
Agreed. My first case mod was nothing more than me painting it blue. That was it; blue paint. Taught me volumes, though, as to how paint reacts...
Why not just mod the clock? There isn't room for amonitor, coat the pendulem and weights and cables in different colors of UV paint. Place...
Well, it's certainly very "tote-able" for LAN parties.
I feel a bit like an idiot asking tis, but bear with me. I've used mutiple monitors for awhile now, but mainly at work where we really arent...
Totally with Fox on this one. The only thing I do different from him is I lay the case on its back (side) and have compressed air in one hand...
Found it at Pep Boys last night. Three can set for $17.99. Probably enough in the cans to do a standard mid-tower. Has the base coat, middle...
RED - GREEN - BLUE
Old question, no good answer. You can only get it to VGA by first passing it through a LCD controller. You can find them at earthlcd.com. Good...
Dude, only people who work for Voodoo suggest Voodoo, and even they know better. Dell will be fine for you; they have a good replacement program,...
True, though I've noticed that with some larger video files (ie. 1GB) it can start to show some major hang ups. Something important to note, many...
it was released in an article not far back (Anandtech or Toms Hardware, never sure which) that MSI sort of fudge's what it reports to Windows....
Depends on how often you access it for storage. Yes, it will be slower than your SATA (not because it's SATA, but because of the higher cache and...
Not to sound like a smart ass, but have you tried fitting it? Do you have the Shuttle right there to compare it to?
All LCDs adher to some standard. It would cost Sony way too much to develop a whole new way to connect an LCD just for the PSP. Likely, its one...
The front has little tabs that hold it in. When you unscrew the rear of the mouse, you then lift it and can unhook the fronts. As for lowering...
If it accepts a composite in, why not just use the composite out from your GFX card? You can even get adapters that convert a VGA signal into them.
It looks like he painted the plexi. You COULD just cut a new length of plexi and paint the backside of it, so you have the mirror black effect....
Build the front bezel to look like a vandegraf generator with the main pillar actually a water resevoir! You'll need hazard tape (or at least...
