Thanks for all the help! I got the old PSU started by shorting out pin 14 & 15 i think. The LCD's not working.. I think i blew it. Reversed...
thanks for the replies:) i managed to get the old PSU working, and take -12v from there. Now i gotta get the LCD working :) Merry...
Hi all, Today i bought myself a Christmas pressie, a Varitronix 128x128 LED Backlit LCD (T6963C). I wired it up according to...
How do I know how many mA's are coming from my PSU?
How many mA??? HI all, How many mA's must the inverter be for a EL backlight of a 20x2 LCD?? Thanks. God Bless & Kind Regards, Richard
very nice!! Is there a guide somewhere on how to build it and connect it to your hdd led? thanks! God Bless & kind Regards, Richard :)
oh so, the two black wires on the molex are the same..?? so why do they have two?
So it doesn't matter whether I use -5 or -12 for negative?
So does it matter which one I use?? Because i feed LCDs +5v and use -12v sometimes on the molex connector?? Thanks. God Bless & Kind...
Hi all! I need to know how to build an inverter to take 12VDC to 90VAC 400hz, to power a LCD's EL backlight. Your help is much appreciated!...
niceeeee! Nice mod!! :jawdrop: Are those normal LEDs shining down, or Lazer Leds? Thanks. God Bless & Kind Regards, Richard :)
thanks thanks guys. if only it was a simpler plug 'n play type solution that even newbies could do... :confused: ?? :) God Bless & Kind...
LCD Hi there, I have some Hyundai 24x2 LCDs that use the HD44780 and HD4410 controllers. The LCDs work perfectly using the parallel port...
Good question! Good question! I would also like to know the answer as I sell Ready-To-use parallel LCD kits and this is something that has come...
Hi all, I do not know what exactly was wrong but I changed my parallel port's mode to ECP and that seems to have fixed the problem. hehehe,...
*bump*
Hi all, Ok well, this is how my problem goes... I have an Ever Bouquet MC2004E-SYL LCD (20x4 with LED Backlight). Now in the manufacturers...
huh Hi there! Whilst testing my LCDs, I have shorted the 5v wires about 5 times.. But [thankfully] the wires have never melted or gone on...
Eeek! I know what you experienced. A few weeks ago I by mistake shorted the +5v and -5v pins on my LCD, and then my pc just would not boot. I...
