Apparently this is all to do with FPS - switching to DX9 gave enough of an FPS boost to clear the input sluggishness - apparently turning the...
Well after fighting for a half hour to get the game into DX9 mode without blackscreening me on load, I've finally got into game in DX9 mode and...
I poked around in the console a couple of hours ago and I remember there being an FOV option - I may be wrong but drop the console with ` and type...
Posting to agree with this, the mouse movement is definitely off - it's not unplayable, but it is certainly annoying and if they were trying to...
Just don't skimp on bits. If you're going to do it, do it properly - get a decent set of components, research the bits you think you might want,...
From london up to leeds and across to warrington so far I've heard. Pretty awesome, if a little bit freaky :D
Well of course, watercooling it provides better cooling capacity generally than a heatpipe or whatever setup, but you have to ask yourself if you...
Seconding this, tom from chilledpc is awesome :thumb:
Yeah the heat is normal. If you can't stand the noise of the pump mounted directly to the case, try & find a way of mounting it where you're not...
Well unless it's a G0 stepping it's putting out 130W or so at 1.35v - bump that up to 1.45 and you're probably looking at 160 or more, which is a...
Well I'm running a QX6700 at the same clock under 1.49v and it's running 45-55c idle and 60-70 under prime95 load depending on ambient temps...
If the voice app you're using allows device selection, you should be able to do this using a USB headset (they should identify themselves as a...
:hehe: Good luck in your noble quest sire, sad to hear about your stuff getting nicked though :sigh:
Yeah same. The difference is however I think at uni if you get caught plagiarising a lot of the unis will simply kick you off your course, which...
Cloak, get within about 6ft but out of view of his buddies, single shot to the head kills 1st time with no noise, cloak back up. Only problem is...
53GB / 11268 Files Mostly in mp3 unfortunately although all the new stuff is in flac :)
My 3g ipod has been going for 4 or 5 years now I think, works fine apart from the headphone remote thingy and the back cover is a little scuffed,...
Unless you get a custom kit (such as the ones done by Chilled PC or Over-Clock in the UK), theres really no point switching to water. Most of the...
I beat anyone in posts per day :p
Hah, I knew it. If i remember correctly, windows will force a drive into PIO mode when it encounters a certain number of read (maybe also write)...
