Just a quick note, if you're planning on running high-quality sound out of this, I'd recommend getting a soundcard, a Creative Audigy is a pretty...
You could try pitching out for a 1.8mm 40GB hard drive that toshiba just released..it's got to be pretty expensive though..maybe you can contact...
Try downloading AdAware and SpyBot Search & Destroy. For virus try AVG Free. This should help clean it up. Regards,
I was talking about the interior. You stuck wood on the outside..but it's not *fully* wood. Regards,
Mil...it's not fully wood..it's just wood outside metal..and even if it wasn't..too much metal visible. The others are full wood :) Regards,
Amazing Zap! I like that Cenobite PC...original and pretty awesome..I think I might die at night though..my computer is in my room..I don't...
I think with the registry/dll issue, Windows needs to organize the system folder, creating a foldeer for all the installed registry/dll's to go,...
One thing I'd like someone to pass on is to make themes easy to edit and add by the native manager (I don't know if this *is* in it or not) For...
Delete it maybe? Did you try that? Go to start>Run>e:\windows\system32\ Then in explorer, delete cjpg.dll Or, go to start>run and type...
Here's one, in a carpeted room, put on woll socks and "chuffa chuffa chuffa" around :P Then touch the motherboard...test it, should short out the...
Or learn linux...it's always a good idea..linux is the future. All we have to do is get a geek's hands on a nuclear weapon..just one..and we...
I think would searching for something on how to bundle your XP disk with SP2 be a good search term..I remember reading on it when SP2 came out......
Photoshop 7.0 is good enough for me :P I'm not much into graphics though..so that's probably why :P I have CS..honestly, I only use it if I...
That reminds me of Peter Griffin.. "I must remember not to go to the bathroom.." ^^ Regards,
Remind me to never let any of you near my computers... 0_o.. :P Regards,
Conspiracy nuts..can't get enough of em :P Regards,
Underclocking...the newest fad in computer modding! Lmao. Why not just talk to his dad, he is your brother is he not? (If he is your nephew...)...
Alright, I got a LinkSYS WRT54GS (Speedbooster) Router and the same Network card, the router is in my room in the basement, my comp is routed...
I'm not sure if this is the right forum to post it in, since I would like a linux based file server, but it says windows and software so I'll...
Awesome, I'll most likely pick up a linksys then, probably get speedbooster, since speed is good ;) Regards,
