Get friendly with a policeman and get him to run a PNC check, not strictly legal but if no one finds out who cares... :)
very nice car, a whole world of potential. Not a bad idea about putting a Mk4 engine into it, but if your looking for a lot more speed for not...
noise cancellation technology was developed by the U.S military (suprise suprise) its most well known application is in appache helicopters. they...
ok, its not a pc mod, but its a mod none the less, and definatley a disaster. while i was at uni, i bought a renault 19 16v. not a really fast...
does any one know where to get novus #1?
either go with what kong and eddie_dane have said, or you could try taking it along to a sheet metal fabricators, im sure for a bit of cash in...
ive got a g4 ti4600 running standard clock speeds, (at the mo:naughty: ) and i wanna know if the zalman gpu cooler and a fan, (an 80mm on the...
if 3000 grit gives an almost mirror finish, 4000 grit finish must be blinding
ive was talking to my girlfriends dad, who works for fujitsu europe, and i mentioned 3000 grit sand paper for finishing heatsinks etc, and he said...
i wouldnt say its completey ugly but it could be better, but damn what a cool idea, and as for the LCD in the swing door of the antec/chieftec - i...
im going to upgrade the heatsink on my g/card and want to know what you lot reckon i should go for. ive got a geforce4 Ti 4600 running at...
yeah they're cool, but i'd prefer a Skyline GT-R vroom vroom :rock:
you can get them from most electrical suppliers, ive seen almost identicle ones to them in the RS electrics catalog, and they only a couple of £
i was just kidding :D
seen these? try the globawin GAT-001 here, (scroll down a bit), http://www.overclockers.co.uk/acatalog/Online_Catalogue_Other_Cases_35.html...
i like the effect of the catodes and the UV reactive/glow in the dark IDE cables :clap:
:clap: pretty sweet dude, i like it alot. it looks nice and profesional aswell :clap: any plans to do something similar to that with the surround...
damn cool :hip: but also damn expensive :sigh:
if you live near a b&q (or probably any DIY store for that mater) you can get draper security bit set for like £3-£4. ive never come across a...
just make sure you got a high flow of air through your case, 4 120mm fans on thie side blowing air in and 4 on the top exhausting air out should...
