"Don't large plasma screens have to be readjusted every few months or so to stop the screen cracking. My friend mentioned it when his screen...
plasma's are rated at HALF LIFE so at 20,000 hours it is in its first 1/6th of its life. Also if you do the math if you watch your plasma 8 hours...
most are rated at about 60,000 hours, like commercial panasonics necs ect. some cheaper ones are rated more like 30,000 hours. Normaly they are...
actually it could be a 15ms response time. I sell lcd tv's and plasma's and samsung is about to release a 19 inch with a 8ms response time. more...
thanks for the help. I found the problem. The guy using the machine had a pop up blocker installed. well for some stupid @#$!*$) reason it would...
hey guys and gals what i have going on at work is this. I have a windows 2000 machine with 2 lcd's. I just got a geforce 5200 to run these. I...
hey thanks for the reply, it turns out that the print server is working fine, except when i use it with a crappy dell printer. I removed and...
Hey Guys see if you can figure this out. I have a d link dp-301u usb print server. The machine I'm printing from is a windows xp pro. It will...
My house mate sells plasma's and his advice is dvi to hdmi probaly will not work because pc output has a verticlal and horizitail sync. hdmi is...
i like the second
i went to http://www.learnwindowsserver.com/ and picked up the videos for about 10 bucks, i thought they were really good. they also have some...
wow what a great series, this had to be one of the best playoff series ever, one more big game 7 tonight and time for a great world series
i dont know how i missed this thread, it may be to late but GO SOX, now just to over come the 2 run deficit and win 2 more after that
im running a asus A8V Deluxe with a 3500, two raptors in raid 0 and 1 gig cosiar 3200xlpro and this this runs like a dream, i would highly...
it is also some time helpful to put the drive in a second machine as a slave drive and run all your virus scans from there. Because if you dont...
i believe there is an option you can check to fix/clean virii in the free trend micro scan. you might also want to check out avg for a free virus...
you might want to try to run this stinger program from mcafee - its free and only checks for trogans/worms. also if you can get to the net you...
how far are you from the router, how many pcs are having this problem(all the wireless ones, or just a few), can you get to the internal page of...
wow 30000, i just got done with a costumers pc who was complaining of slow internet, he only had 1800
D*&* i though i found alot on a costumers pc when i found 1400. I was funny how amazing he thought i was when i showed him his pc after i got done.
