thats great, thanks for the site ill have to get it after xmas as the postal service is silly this time of year thanks guys.
ok thanks for the help i may ring around next week or pop in to some of the local model shops and ask them and see if they have the answer....
hi im in need of a UK available acrylic glue, google brings up nothing of help and i searched for Methylene Chloride which was used on some ones...
thanks for the swift replies quys :D
hi just another quick question, say ive got some 12mm thick plexiglass and i want to place a bolt in the 12mm bit to attach it to a case. it needs...
aaaaaargh so simple :blush: im embarrased, anyway thanks a lot for the help now i can order some and get modding :dremel:
Can some one please help me understand this hol M3,M4,M5 bolt thing i dont get what it means :wallbash: does the "M" mean metric and what does...
hi thanks for the reply glider your post contains a lot of information that i found usefull, thanks :)
hi, when i found this and read some of the links posted i realized i was one of the many unbuntu noobs, and id really like to give a go at...
nicly done yet again is that just a grinding stone u were using on your dremel to shape the plexi?
:D yeah thats a great looking case i love the pic of the inside were its lit up blue it looks frozen ellexent work there defiant u inspire us all
yeah i like the background and the dremel silloute, just i had to look twice to read what it said which you dont really want if you looking for...
^^ Agreed
:sigh: i now what you mean MoOstick, im loving the hard drive rack, and i hope it helps nock a few *C off your mobo temp im looking forward to...
great update, i really like your work and find it very inspirational, :thumb: did this power supply come as standard with your LCD or did you...
hi, some more brilliant work by you, can i ask how you are going to power the lcd as i dont see a power supply and ive got a almost idenctical lcd...
hi sorry should of mentioned this in the first place rite its a Packard bell ft500 rite i got the camera out and tryed to take some photo's but...
hi, well i just got a 15" flatscreen tft off ebay for £15 only fault is that the power suply is screwed. so what i wanted to know is what voltage...
aaw cool, going to have to keep my eye out for one of those :dremel:
nice mod were did u get the clear acyrilic pipe from?? :dremel: i wanna try this mod out :D
