I attempted (got a BSoD during the middle of it) to install the newest Catalyst drivers since I was getting some BSoD problems frequently from my...
Hmm, good ideas, but I think that in the end I'll just snap the piece off. A bit of tape and I can ghetto rig it up, so I'm not too worried. I'd...
The head is completely screwed, which makes my life a lot more difficult because it's now stuck in there. If the threads were stripped, I'd be...
I've been popping Advil for a while now because I have the biggest headache ever. I have come to the realization that 512MB of RAM does not cut it...
Agreed - I'd go 8800GT before the GS though
What kind of price difference would you be looking at if you went with the 8800GT, or any of them for that matter?
Sorry to bump this thread back up from the dead, but 1 - Thanks for the heads up on Windows. I was planning on getting a 64-bit OS so I should be...
Yes, I will be using it primarily for gaming. From what I've read as far as reviews go, it's good for gaming....hmmm....
ROSEWILL! Sorry, that was a horrible typo :p I meant to say Rosewill instead of Corsair :p Also I thought the lower ms was better?
thanks for the link - I think it's safeish to say at least a 550W PSU should do fine, of a good brand. I'll definitely go with a 'No' on the...
Well I don't mean to add to the stereotypical "CHECK OUT MY PARTS LIST" threads, but I need some feedback on a system one of my buddies set up for...
For the sake of file sharing, I disabled the firewalls on both computers in case that was maybe something that could be causing it. It looksl...
Alright, so here's the deal... I just got a laptop computer today and I am having problems setting up file sharing with my desktop, so that I...
I'm going to be setting up watercooling on my next PC (Hopefully the next few weeks!) and I was wondering what I can do with my Hydor L30 as far...
Do you have Menu Transparency on at all?
WOW I feel like an absolute TOOL for not finding this sooner...fixed. Went to Start Menu Properties (right click on the start bar anywhere,...
Yes I can, but no it doesn't make a difference. Also, I can right click on 'All Programs' but that's it...so it's not the entire start menu,...
Nothin....bleh, idk what to do, apart from another reformat =\
Custom, but changing it hasn't fixed the problem, whether I go to a different theme or just the standard one.
Yeap, newest drivers are installed and all the Windows Updates are installed too.
