So, can someone explain this:
Since my dvd player is already connected via component then I shouldnt notice any difference. I found a Radeon9250 with dvi-out for $60....
The problem is the mobo doesnt even have an AGP slot! :( What will happen if I get the vga-to-component cable, will I lose quality with dvd...
Could I use this: http://www.lenexpo-electronics.com/product.php?productid=16189&cat=276&page=1
I have an old Sony VAIO with onboard video (64mb) that I'd like to use as an htpc. My hdtv is an RCA Scenium with HDMI, S-Video, Component, and...
Final score after streamlining BIOS and RadClocker= 6410 Abit NF7-S 2.0 2500+ @ 220x10 (1.7Vcore) 2x512 Corsair XMS 3200 @ 11-3-3-2...
Ouch. That sounds painful. :D
Ive tried DNA and Omega drivers. Any suggestions on something better? I play mostly CS:S.
Small scratches here and there. The side panel needs to be redone. The design is all out of proportion. Gel ink marks everywhere. Sleeving is...
Im starting all over Unfortunately Ive had to RMA the mobo. After loking at it for a few days, Ive decided to start all over. There are too...
Unless you make mobo tray rails, doesnt this mod only serve as a mobo holder?
Wouldnt worry? It sounds like battery juice is leaking from it. It is a very bad raspy/hissing noise. Not a high pitched whine. Ive requested...
Mobo- Gigabyte GA-7N-400-L CPU- 2600+ (non-mobile) Mem- Mushkin 2x512 3200 PSU- CoolMax 450 I hear a nasty hissing/ticking sound coming from...
I was hoping for "consumer" feedback.
I made the mistake of buying a p.o.s. CoolMax for my girlfriends case and I think its giving problems to the 12v rail. She likes how the Ultra's...
So...go buy some?
Hey, whatever works right?
240 baby! Looks like 240 is my limit. I hit 56'c on my ghetto "extremecooling" setup so I decided to back everything down. Ill be fine at 220....
I cant get over 220x10. If I try 221x10 or 220x10.5, XP doesnt load. Specs: Abit NF7-S 2.0 (flashed BIOS to d10 Mantaray XT) 2500+...
Theoretically, which is better for optimal performance? 200x11= 2200mhz or 220x10= 2200mhz CPU is XP 2500 VCore is 1.7 to 1.75 Mobo...
