Wow dude..thats awesome
you dont need to wait for week and so on,just touch the psu heatsink with isolated screwdriver and that's all ,it will discharge
i think you should hide that ccfl somewhere in the top of the case ;]
its working only for winamp ? or i can use it for everthying in windows ?
no its near baltic sea near latvia,estonia
check you adapter cause its really look like its working bad its just power notebook how i know to power notebook you need ~12V to charge battery...
i think that your notebook adapter go to nowhere read on notebook back how much volts it need to charge and check with multiplier how volts your...
wrong sending 1kg from USA to Lithuania cost 15$ and you receive your package in 1-2 weeks . And another question you want to have something like...
is there any problems 'cause then i tested my irq the vga and lancard has same irq
go with this http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-036&depa=1 it looks kewl :dremel:
i think you can put molexs n your backplate and then plug-in from atx psu to those molexes
ok maybe it was asked here but i cant find :/ is there any of interner shops for modding products and hardware that can sand their products to...
i am using einhell company dremmel and i think that there is no differences between original dremmels and clones if they are not very cheap :worried:
damn that window looks awesome :rock: :rock: :rock:
or a dell with centrino :D
sorry for my stupid question but i dont know english very well so its a bit difficult to understand that sheme.Here is the question: i have to...
for me its dremmel, drill, jigsaw, a lot of screw drivers(i don't know how exactly its spelling)and other small things
that you think about pump > rad > rad > blocks > res > pump ?
Hello , i am n00b in w/c and have few questions is there any diffirences than i put radiator before reservuar or after? thnx Black
solder another button tu the cd-rom button that is inside.I think you understanded that i want to say ?
