If you want it quiet, these 60mm fans are the best choice. I would try one huge 120mm fan on top, running at 5 V. Or just go for complete...
At first, thanks for your good feedback! @TMM: Check post 25 for the signs. I'm not sure about the specs right now. I won't buy the hardware...
It's chinese :D And translation of every sign would be much typing work. But every side has a "theme", so here we go, from the left: top...
I took a picture of all the signs, maybe it's interesting for someone [IMG] [IMG] And here some pictures of the equiping process: 1....
@exavier412: That is true, the light would disperse better and that is what I don't want ;) I want to light up each sign individually, so close to...
Long time without update, so here we go.... First I had to cut out the signs. 15 plates with 6 signs each makes a lot of work, believe me!...
Nice work so far, looks good! How did you make the etching? Looks really l33t! Put some LEDs in the Plexi to light up the etching, so no one...
Look for a nice LCD that fits in 2 3,5" slots und mount it so you can flip it down. Then mount your floppy behind it. May need some :dremel: but...
The display looks quite small. What are the measures of it? One of these PS One Displays (5" diagonal) should fit very good in two 5,25 bays....
@ all: thx for the comments @ atomsk: I think I will buy the CPU block, but I already ordered a solid 100x160x10mm piece of copper :rock: to...
When I read the first line I thought, "Uh, have seen pyramids before and I didn't like em" But the pics loaded, and I've to say: Your case...
Hi folks! In early february, the idea of building a case from the scratch came to my mind. After much planning and research I finally started...
