Thank you for the answer. My english is still limited, but i understand better the english, since then i'm on the english forum...
Hello, Thank you for the answer. My english is still limited, but i understand better the english, since then i'm on the english forum...
I have finished the paint. [IMG] Shot with DSC-P93A at 2007-07-29 [IMG] Shot with DSC-P93A at 2007-07-29 [IMG] Shot with DSC-P93A at...
Hello, I'am Julien Arrachart, of the TEAM (rédacteur) PC assemblage (it's a french magazine). And, we published the mod of derbaum : [IMG]...
Thank you ;) Hello, Of news ^^ : [img] [img] [img] [img]
Hello ;-) I have continued the mod, this day. I have cut two line for the power and / reset, And to fix the plexi UV behind the cut (letter)...
The today news :-) here, example of hardware site : [img] [img] I will make the interior of mod in the next days. And i cut the...
Hello, For the glowing, it's a Cold Cathode (Lighting)...
Ton français est bon ;) (your french is good). English This mod, is on the design "enfer", because it's the in the theme of web site :...
Hello ;) After, my old mod ("Kanjis-Furious") : [img] [img] [img] I begin a new mod, always in the same style but the design...
finaly, i took the Alu aluminium color coppers. It's less expensive. it's of 0.3 mm.
Thank you ;) [img] [img] [img] news of the cut :)
it's cut with the dremel, (with a disc diament). ;)
the cut : [IMG] [IMG] [IMG] :)
Thank you :) For the structure cube in plexi (plexiglass), the plates outside will be in copper (cuivre). just the pleasure of modding ^^...
Hello, My mod "Furious-Kanjis", is almost finish, (it remains : Gaine of cable, Rack of hdd, and some details...) Here, the photographs...
ok ;)
thank you :) I haven't not paint the DVD, because, it is not that of mod.
Fixing of the foam on the bottom of the case. I would make photograph with the neon and cooling. and the photographs of The night....
thank you :) You woun't stealth the dvd, and what is it gonna be in the other hole under the dvd? : The L.I.S prenium, lien :...
