I am using an Acer laptop with a Radeon 9000 64 Meg Mobility Card in it. I just bought a 19" LCD monitor, and am trying to hook it up to have a...
Okay, I am building the circuit, but couldn't get my hands on an 8 volt zener diode required in the schematic. All I could get what a 5 volt and a...
Okay, I finally got the chips in the mail. Now, I am gunna build this programmer. I am going to use the circuit you suggested to me:...
Hey I am a noob in the microcontroller department, and I wanted to buy a 16F84 and a programmer from it on digikey. Unfortunately, Im too dumb to...
Thanks a lot.
Hey guys I cant figure out this diode problem. [IMG] Using load line analysis, determine the voltage V for a) V1 = 5V and V2 = 0V b) V1 =...
Okay, it turned out a diode was bad and when I replaced it, the board stopped sparking. The only problem now is that to access the back of the...
I have an RCA TV model number P46732BA which recently stopped turning on. I opened her up and found that the power board was sparking when I...
Okay, I found a 3.7 VDC 0.35 mA charger lying around and went balls out and started charging it. A red LED started blinking so at the moment I am...
It was the buckingham palace tour that they only give for 2 months each year.
Okay, I read the card and it has a bunch of MP3s and stuff. Seems pretty easy to change, but it will all be for nothing if I cant figure out how...
Last week I went on vacation and visited Buckingham Palace. I took the audio tour and when it was over, I accidentally forgot to give back the...
Poop is an idiot. He knows nothing. Using ICS in windows, this can be easily done with a crossover cable. :waah:
Okay, I got the LCD to display and everything, but I now have a new problem. When the lcd is running, the characters on the screen move around and...
Herdkilling - The PSU is not an issue as it does work in other computers. Shorting the two pins does no good but thanks for the idea. Risky - I...
My computer just started acting very strange. Now, the power button does not work. The only way to actually get the thing to turn on is to remove...
Okay, I wired everything, but I used a 100Ohm resistor instead of the potentiometer. When the lcd gets power, it stays blank and does nothing....
I just got my new Seiko L2014B5A in the mail and have begun wiring it. My question is, do I need to use pentometers or can I just wire it directly...
I have a portable lcd television. It seems that the video controller chip is a M51348FP. Here is a link to the datasheet on it:...
what what?
