That's an odd one. Just out of curiosity, does your PC have a Broadcom NIC? They are notoriously bad at speed negotiation. More over, are you...
First off, sticky, awesome, lots of win! How much of this applies to US consumers? Wading through google right now. If a consumer armed...
I've never been brave enough to try it until now. I'm curious how "quiet" it's going to be compared to my current rig. I'm running 4 fans turned...
While manufacturers of sealed loops may have low/no bateria in the loop from the factory, we can assume home made loops will be contaminated....
Your PSU soap-box gave me a chubby. I've got a 550W that's been running close to 24/7 for the past 4 years at 70-80% load. Still running fine....
Wicked_Sludge, By no means am I attempting to debunk your testing method, merely suggesting improvements. My theory is there is probably a...
I know this is an old thread, but I'm curious if anyone considered flow rate. I'm curious what your actual flow rate is with mineral oil and if...
Well, I've been window shopping online for the last week and I'm having some trouble with a couple things. First thing is a correction: I have a...
Oops, forgot the CPU, I plan on an i7-3570K. I will overclock this system a bit. As far as the case, I'm currently designing an aluminium/wood cube.
Hai! So I'm planning an upgrade on my dated system and looking for a quick sanity check. Gonna be used for Blizzard games, Minecraft, and EA...
Motherboard is fried and the PSU is fried. Was hoping to salvage the CPU, but it wasn't in the case when I got it. :/
If I'm not mistaken, changing the OS drive would change the unique system ID and could cause a bunch of errors in event viewer and/or unexpected...
Hi all, I bought a non-working HP Proliant server off of ebay. Astoundingly there were two Intel Quad-Port Server Class Gigabit NICs in it!...
Not sure if anyone has spent the $$ on one of these, but I did. I also apologize for my terrible photography skills. Anyways, on to the important...
