thanks mate!
+1 it's nice and very artistic! looking forward for the final build!:thumb:
looks nice... i would really love to see the photos in the first post... keep it up bro!
yes sir! pinoy na pinoy ito! and proud to be one! Happy new year to all!!! Just got back from a short vacation! Well, a new year is...
thanks man! :) thanks mate, it took me 3 scratches just to come up with correct bending method for the mobo back panel... i almost quit...
hmmm... I don't think this mod falls under visual display... as what the instruction says: Unless you put an lcd infront of the monitor, it...
No problemos amigos! :D always glad to help! here are some photos again... this time psu sleeving! [IMG] hahaha! What a mess! :duh: [IMG]...
looking good amigo! just wanna ask, what will you do with space underneath the 2 blowholes? are gonna put a bunch of hard disk there or more...
here is some good wood works... nicely done mate!
I almost drop my head when I saw you cut the ATC into half...:jawdrop: as always nice work coolmiester!!!:rock:
thats a nice idea chris and a sketchup diagram would be much appreciated!:rock: thanks... you can always make one... there's a lot of ways...
Thanks mate, it fits fine... it lift a little when i was using it because i have to use a dvi-vga converter to connect the monitor that I was...
yeah... i love the raven 2... before this build i was gonna get a raven 2, but it came to me what if i'll build my own case inspired by the raven...
Thanks, I haven't design it yet! by the way, here's a photo of it during the event... [IMG] it has identically side panels... I have to make...
Forgot to post photos of the top cover, so here it is... [IMG] [IMG] [IMG] [IMG] The top vent will be a combination of translucent...
thanks... it was really a simple procedure, i have drilled a 6mm hole on both ends of the pci slots then cut it with a jigsaw... and then i use...
Hi everyone! I would like to share to you the worklog of my very 1st custom built computer chassis. I called this one "Alpha-Custom", since it is...
this is really what you call build from scratch! even the barbs are built from scratch! great job!
whoa! i thought it gonna be build from scratch... but anyway haf x is a great case...
wow it's so nice!
