Buy a new SSD ... your Corsair only has a three year warranty and you're two years into it .. use the old one as a backup drive or page file/temp....
Could be a driver issue (note that memtest doesn't always spot errors though). Try re-installing MOBO and GPU drivers? I'd try one driver at a...
I expect they are .. I meant this: "4 x DIMM, Max. 8 GB, DDR2 800/667/533/ ECC,Non-ECC,Un-buffered Memory Dual Channel memory architecture"...
If it's been sitting around the BIOS might have reset to factory default ... as it's a workstation board it can take different types of memory so...
Dr S, Simple Machines Forum has a built in calendar that works pretty much the way you describe. Going to be less headache than setting up from...
[IMG] As per the above image, the Corsair CX600 has an 8/4 pin CPU 12v power pin - think you are mistaking this for a pci-e 8 pin. Break it...
As mentioned above you could use WordPress with a forum plugin .. Or you could do the whole thing in Drupal, powerful steep learning curve Or...
As someone commented build a system, become tech support for life! Might be worth installing team viewer while yr there to enable remote tech...
Neil, One thing I haven't seen mentioned here: when installing Windoze just have the ssd plugged in, otherwise the installer may well put the...
One long beep two short is a memory problem. You might want to check the QVL on the ASUS site. Even if the memory is listed one or more sticks may...
You can reduce roaming issues by setting devices with a fixed IP ... as long as they stay in the house it's no issue. Regarding the split use of...
You won't get seamless roaming ... if you actually move around the wireless device will hold whatever AP it is associated with as long as it can...
I bought one of these from China through Aliexpress for about £97 including postage: 10.1'' Ainol Novo 10 Hero Cortex-A9 1.5GHz Dual core...
I have the TP-Link 200Mbp/s version plugged into a hub feeding my main rig, internet-able TV and anything else I'm experimenting on....
ditto
Defend actions by the council as a lay legal friend. Nothing fancy, but lawyers are boring and pernickerty. Thanks for the heads up bro :search:
Thanks guys. Been in court yesterday and today ... bleh ... won one lost one but I'm knackered ... will take in all your helps in the morning....
TGS stop showing off ... first your folk ruin the world economy then you boast about low prices! (Jokes ... Yr a good fella .. seem to recall I...
PCPartPicker part list / Price breakdown by merchant / Benchmarks CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor (£161.99 @ Aria PC)...
Thanks Cei, DarkWisdom, OcSurfe, Won't disagree with any of your advices. He doesn't need WiFi - the router is on his desk. Personal pref is for...
