Bottom left picture on the second page is linked wrong. Edit: Fixed
Notepad is always an option.
WoW starts at 60. Yeah the night elf starting area is terrible and elwynn is cake.
Hey icecoldidiot get out nobody likes you and nobody wants to read your idiotic posts anymore.
milkdrop (should be built into winamp)
look on the first cd sh /mnt/cdrom/Linux-installer.sh or however you want to do it
dvdshrink will make an iso of it
any of them
wine has really improved over what it was but cedega is kinda going downhill another suggestion for dual booting
stages 1 and 2 are only a couple extra commands compared to stage3 and they are still in the handbook if you read all the text along with the...
the minimal cd is exactly the same as the full cd but without stages or portage snapshots, i really dont see why fdisk wasnt working
gentoo... binaries... ha a stage3 would be fine and it really shouldnt take that long compared to some of the boxes ive installed it on
its a command line, everything is a manual install but its portage makes it much easier
what are your cflags set to? genlop says xorg only took 26 minutes on mine, is there really that much of a difference between the 3800 and the 4400?
nope nothing hard other than fixing it if something breaks when its trying to compile and 6 hours?? what were you installing? didnt take nearly...
http://www.rush.com/
not bad at all, provided you aren't on an amd64
how do you set the single cpu affinity?
