yes you can but for a lot of people it is to confusing as they dont know what the parts do and why they are important so they cant make the...
i was never taught how to write my cv or plan my finances on a spreadsheet in my lessons. like has been mentioned our teachers didnt seem to care...
i left school 9 years ago and even then i used to think why is ict nothing to do with the actual computers its just how to use word, excel and...
Well i was going to get one to replace my old PS2 which is starting to mess up a bit. But it looks like i will be buying a new PS2 for £50 or...
I suppose a room a room full of the machines at a show under spotlights are bound to get a little to hot and crash sometimes. my old PC used to do...
Just joined on my works laptop will put this on my computers at home tonight as well. Does the GPU one only use ATI?
I will buy an OEM copy when i buy an upgrade or build a new rig to run Vista. Then i will be able to use DX10 and use whatever is the best of...
I had this problem on my last computer. I had it custom built 3 years ago with a Athlon 3000+ & 1 gb RAM. That was all i knew about that affected...
Does the question mark on the news title mean anything? Is this just a rumour?
Absolutely nothing, but you can't blame them for putting the PS3 on maximum priority, how many of the general public couldn't give a damn about...
Here it comes, sony bashing time again and that quote.
there is a burner available from Pioneer From Overclockers Its good to see them merging the formats as long as the players dont cost as...
Finally managed to get the 64 bit version. One problem: 1. Limited internet. It will load part of a page then the download will freeze and i...
If you look in the games section the games are also on pre-order and are going to be priced at £49.99. So you would save £25
For those that have not seen it yet PS3 at Play.com Look at the price on that :jawdrop:
i have been using AOL for 3 years now and it has managed to destroy 6 hard drives in 2 computers (all by deleting the OS and the hard drive...
cheers for that guys, i have just installed it and it works no probs, bit different to norton (in a good way) i knew this would be the right place...
I recently finished building my new computer and decided that instead of buying a new copy of windows xp 32 bit i would download windows xp 64 bit...
I need some help finding a psu for my new computer i have had a look myself but cant find one to the right spec im planning on taking it to...
right ill just use 1Gb of ddr400 ram then Cheers :thumb:
