If you end up annoyed at the lack of EDID emulation (and possibly not enough USB power for some devices) with that one, then this is a great deal...
Cloud storage for that much could easily run to £10k a month, so on prem is probably cheaper if you're happy to handle the failure cases.
I found when buying and returning a couple of damaged computer cases to Hungary that even though I returned them, there was pretty much no way to...
The most accessible book I read to get into the mindset was "The Design of Everyday Things" by Don Norman. It's not a UX book, but it's human...
Something that's useful and often overlooked is a non-technical/semi-technical UX review of software/websites. Having a partially technical and...
I know one example isn't any kind of proof, but I have had 16 5TB 2.5" SMR drives in 2 8 disk ZFS RAIDZ2 arrays for 3+ years. The only issue I've...
In all honesty you'd probably be better off using the free/cheap tier of a hosted service. No headaches and no development. It sounds like what...
@MLyons does someone reliable own the IP/trademarks and forum data? If not then it could easily get taken down/sold/sued out of existence. I'm...
When I try to access the forums withy VPN (SurfShark) I get a message saying my IP is banned. In the current borderline surveillance state of the...
If you're using a really fast drill you might ned up melting it, I've done that a few times. And as the others said, a scrap wooden block...
I spent half an hour playing around with the styles, here's the result*: [IMG] *I'm no graphic designer... Most of what I did was align...
Here's an example that shows the different purples, different gradients, different styling and some of the random colour scheme being used across...
It's not that it's a pain to read, it's mostly that the way things are misaligned, the colours are close but not identical, and that some parts...
Sorry, that's my mistake.
I also agree with all this. Especially the sacking part.
I want to start with saying that it looks like a lot of work has gone in to this, and the site was in desperate need of a refresh. Also that I'm...
