Yes that was meant to be the point. So many people have problems that the rage and score the game a 0 or a 1 on metacritic. A few people like it...
OK, CardJoe. I believe you. But 3.5/10 was the average from having so many people rate it a deserved zero for being unplayable. The game is broken...
Check the user reviews. 3.5/10 at the moment and falling... http://www.metacritic.com/game/pc/call-of-duty-black-ops Official reviewers that...
voice acting that can only put eastenders to shame... lol
A lot of people might be disappointed with network throughput for NAS samba file sharing. If running gigabit ethernet, the best speed upgrade...
You are obviously someone that is so impressed with the high numbers that you would buy this mouse to increase the size of your e-peen. Show me...
These so called gaming mice are pretty unimpressive. Small, plastic, basic even mouse with a stupidly high DPI rating. Why not just turn up your...
It's 16:9. The 27" is a cut down version of the 30" dell. I believe they are the same width. Just cut some of the top off the 30" until you end up...
I got a 5750 for £88 from ebuyer. That's the best value graphics card available right now. Should get a solid recommendation.
It's 25nm and it's coming in Q4. New Intel drives are probably along same time or shortly after.
I want to know, why does fermi perform so badly considering the number of stream processors it has? I thought it should have no problems...
It's prob tall enough as long as you dont have tall RAM. It looks like there are better coolers on the market already tho so it is moot.
bit tech guys - you have to get a sample of the Prolimatech Megahalems. They are superb heatsinks.
If you want to save money and save the environment, you get a 2nd hand car and keep it going for as long as you can. If you are going to buy a...
I found the same thing. 0.8v at 1GHz. Under load I undervolt as well so it's using somthing like 1.1 or maybe a bit more. It's 100% stable but...
Yes but when the web page is loaded, the PC is just sitting there idle while you read it. I did say if it was idle most of the time, not all the...
If your PC is idle most the time (like if you browse the web, listen to music, etc), then idle power draws are much more important to focus on....
£100 without the wireless N.
Doesn't look that gory. Half Life had more gore when you hacked people to bits with a crowbar. Left a right mess on the floor. Never seem to get...
These mobos are junk. How long have we had DVI connectors now? Why aren't they on there? No gigabit eithernet? This isn't 1999. Even the power...
