No, not sarcasm :) I've heard nothing but praise for EVGA and their warranty program. I don't actually have any EVGA stuff at the moment but...
EVGA once again showing why they are a first choice for PC components.
You could try adjusting the fan profile to let it run a bit hotter but with less fan speed? Maybe move the PC?
Seems to me he is deliberately selling counterfeits and he knows it but is trying to avoid loosing reputation. I would file a claim via ebay...
I'll try a different slot tomorrow. It's never happened while idle on the desktop but it has happened once or twice while browsing the web or...
Windows 7
I've been having this issue for a while now but it's getting to the point where I can't play a game for more than a few minutes without the Nvidia...
I have the Luxe and it's not a bad case but I would suggest checking other options or wait for others opinions.
I forgot to mention the result of my google search - It seems to be a firefox bug that started when youtube switched to the current player (HTML5...
I've googled the issue as it's been ongoing for a while, youtube videos are bumping CPU usage to 20%+ depending on quality. 1440p + is unwatchable...
I'm looking at upgrading my trust i5 2500k since it's starting to show it's age with most modern games + youtube is pushing it to a constant 100%...
I'll second this. I made the swap after my Naga started having the infamous double left click issue that has been around (and not fixed) since...
I have a phantek Enthoo Luxe which I wouldn't recommend.
There has been some great tablet deals on hotukdeals recently. I picked up a HP slate 8 pro for £120 (should be £220) via HUKD. Not overly...
DPD have been great for me. Never had any issues and when I had my new case delivered the other day he was kind enough to bring it into the house...
I upgraded from a 560TI to the MSI 970 and it's awesome :). Using Afterburner I've noticed the fan only comes on for short periods and only goes...
I bought a 840 pro a week or 2 ago from amazon and it was £85 so I would either get the mx100 other people are suggesting or wait for the 840 to...
Just a tip for Tflight hotas X users - if you are having trouble with the twist grip because you keep turning it when you don't mean to there is a...
The problem must have been with the back part because I reassembled mine and everything s working as it should be :clap: and in the process I...
crapbag pm me your address and I will post them tomorrow if I remember.
