Have you already tested the block? checking how big of an flow killer it is.
Hmm that block looks like a real flow killer, and i mean really dead :P. And why didn't you use copper?
Ok, i know a shop in my own country where they've got the remote and the board and they can probably get the rf transmitter. But does anybody...
IR is cheaper and more sets available but i RF will give me a bigger range. Something around 10 meters.
You need to add the receiver module to make it an remote board. I already saw it but i was in doubt if it has an way to switch from on/off to...
I'm looking for an easy way to creat ore a standard kit for doing the following: I want to use RF to switch 4 relay's on and off and alsow 2...
hmm i'll first check the size of those lian li wheels, it's easyer modding them than building one myself. Nice round wheels are hell to make,...
I haven't got the equipment to make a thing like that. I only got things like drill,dremel, grinder, enz @5aboy thnx for that
New update in the project log
Been bussy this week with school and building a wc setup in an other case so a small update and some older pics i forgot to post. first the...
I already orderded the stuff. And that company doesn't send to country's outside the US
alot. I don't wanna calculate it because i know it was enough to buy a nice vga.
k sry about that. Never used anything but broadband internet but what are the pref sizes of the pics? 640x480 ore so? Edit All pics are...
On this thread ore on the project log?
againa small update I'm also looking for some wheels like this but in black [IMG] I used the picture from a project here on bit-tech but i...
again a small update. I now created the sides for the lower frame. [IMG] [IMG] The corners and the edge between the frame an the case will...
I love black so it will be painted Mat black. The wheels will probably change becasue the case is instable and i don't linke instable cases....
wow very nice side and top panel
First update. Bolted the bottom frame to the case, just used some nuts and bolts. [IMG] I picked some alluminium up togetter with an 2mm...
The speed of the penumatics is ok i guess around 2 tot 3 sec to open the door. That mobo is nice for now but maybe going for crosfire with an...
