So now it just came down to finishing the trim, installing the plexi, and doing the build. All of that went just fine, and I didn't take any...
Whoops, I didn't really mention this is a post-completion log. She's all done. So next step, now that I had the important bits in place, was...
Hi folks. This is my favorite modding forum, even though I don't post much, so I thought I would write up a log for my latest mod. I began on...
Okay, thanks. Yeah, I'm still not 100% on whether or not i will have a side fan blowing in, strange though it sounds my PSU might be in the way...
I'm a bit concerned over the airflow of my new case, so i wanted to make sure i had decent cooling on the video. I've been using a ghetto job...
I bought some split loom from radio shack - overpriced or whatever, it was $4 canadian and used vynle (sigh, i hate that word) dye to dye it blue....
Wow, I love that case. Fantastic attention to detail, it looks perfect. I love a well executed breifcase mod, and that one is great. I can't...
The stained glass is the logo of an old, defunct skate company named H-street. I have always liked the logo since I was a youngin, just doodling...
Okay, I thought I would start writing this up as a project log. I showed a bit of this in "mod" forum but thought I would do a full log. I'm...
I knew I would like the final result. Looks really good. Do you have plans for further cable management, or is it pretty much impossible?...
Man, I have to thank you. I'm building a wood case and I have spent many hours sitting and staring at my power and reset switches I harvested...
I thought I would put this question in here instead of starting a new thread...I have two ccfl inverters (dual) both of them blue, and I was...
I really like the look of that so far. Looks like a lot of work to get it all fitting so well, I applaud your abilities. Good work, keep...
I busted an ECS mobo, which I had just purchased to replace a mobo with a dead agp by scratching it with a butter knife while trying to put on a...
A desktop case would have lots of room to make a nice window...I would suggest brainstorming a pattern you may like (something you doodle, a...
I gotta pipe in and agree with Hazer regarding pleasing yourself. This junk about not using blue lights because it has been done is just that,...
The ps that will actually be going in there is a blue-led pretty one, so I don't need any painting on it, which is nice because the PS will be...
Stuff like this is why I try to make friendly with a local pc shop in every city I live...they should have dozens kicking around, I would try any...
Okay, I wasn't able to find much but i found a few places for you... http://www.auto-paint.co.uk/index.htm Best one i think I got the...
As I posted in this thread you can get the stuff for a reasonable price. From what I could tell it looks pretty good. I'll do a quick search for...
