Id disagree with that. Many people can make cold cathodes if they had the right parts. I have seen experimental kits at electronic stores too....
Only issue with that statement is that if you do a mod to lets say a case but are able to revert it back to original stock it doesnt void teh...
There is a big difference. Having a store bought panel with a specific design or whatever in the side of it is a premod. hence all those cases...
When has adding a premade light system ever voided a warranty. And what does voiding or not voiding a warranty have to do with anything Just...
Adding a cathode to a case does not void the warranty of anything!!!!!!! Adding a cathode that is pre fabricated just by plugging it into a psu...
K so my other computer is done doing what it was doing and I worked on the top lighting. I sort of like the case without it but many where saying...
Well maybe to an inexperienced person that doesn't know how to measure or cut things straight lol. Sorry about your luck though. Also If you...
Well if the show does take off then the show should be paying the costs to get people to come on the show and do their thing. Also whatever is...
I say a rivet gun might be a good item to have as for the i/o panel I dont see the issue since most mobo's come with one and you just need to...
A black gril would have absorbed the light and was an idea at one point but I decided not to go with it since the painted silver grill looks way...
Here si some more sites that will validate that my system is ok. http://www.cluboverclocker.com/reviews/video/joytechapollo6600gt/p3.htm...
Whats wrong with my 3dmark03 score? I got 8145 which is 2545 higher then your setup and sounds on par. I also am not overclocking. Also...
Thought since i have a couple pics show what is going in for the top lighting. I might build something different. Anyways I took my old kit that...
Is that all he has modded or has he done other mods?
I never got to see this completed from the other "cough" forum I was in and know its been awhile but nice job man. Love the matching desk lol. :)
Don't use the universal one for both male and female. Those will damage your pins. I suggest to get a tool for each of the pin styles.
What mod did Christopher Dols do?
Thanks for the info bigz. Where you able to overclock at all?
well I am talking about a 6800gt on a pci express line so a bit different to what you are doing. As for your reply to about the slot being 1.5...
Yeah I know that. Thanks though. I wanted to know exact numbers because i have a range from between 85 and 105 from all over the internet...
