I noticed this problem after the first power-up while fixing a grouding issue, although none of the after effects you mentioned occured. It has...
The PSU is finnaly done. [img] [img] [img] Except for the cables, it looks stock, which is good. Too bad it seems to have died on me after 10...
I had figured it was something from that sony car stereo in the pic, but im dumb like that...
Could you possibly elaborate on what your asking a little more? As I understand it, you want help with how to set up your computer in your...
I was going to use the original pieces in 4 places that fit an atx board, except that I would have needed to shorten a bunch of stand-offs and...
Ouch, thats going to be a hard time of placing the mobo standoffs as that is one of those cases where the mobo was mounted on plastic clips, so...
I got two of them from the ebay auction warehouse I worked at. We didnt have any sgi keyboards on hand and they werent valuable enough to sell...
It seems I've severely underestimated the popularity of the Indigo... Anywho, heres a peek at my indigo, which looks the same as the rest of em,...
Ive finally managed to get around to a starting a case mod which my brother isn't screaming at me to do for his lazy ass (which all sucked on...
He had said earlier that he salvaged it from a flat panel display he had purchased on ebay. Gotta love the backround in your desktop screnie =P.
Does the card have any of the connector that need to be screwed in when connected? If so, you just need to remove the things holding them, they...
I did exactly the same thing a while back, except I went cheap and used the n bridge of an old asus board, which I removed with a butter knife =)....
Would a curved window be to your liking? Im currently getting sketcup set up so I can mod your file.
Hey, thats the same welder me and my dad used to fix my brothers car so that we wouldnt need to replace the entire crankshaft. Anywhoo, is the...
I mean the one that turns 90 degrees so that it is right side up whether your system is flat or vertical.
I hope one of you guys will keep the rotating ps logo on the drive face, that is my favorite feature of the whole system, even more so than most...
Interesting card cooler there, gives me ideas. My brother has a very similar case and keeps bugging me to stealth his drives, but Im so lazy,...
If time/tools permitted, it would make for an interesting project to replace the live drive bezel with one of the stock plate covers from the...
No progress, all the junk is cleaned out but still no boot, I cant take it apart at the moment because I still have this lousy covering on my...
Instead of doing that, I sold all my extra hds( about 5 or so) and bought 2 80 gigers that Im putting into a rackmount system I got for cheap....
